I have the Pro4 series of cameras. Does anyone know how many people can be invited to share access? And also, can we all be on the app concurrently? We appear to be bumping each other off of the app if more than one person is on viewing cameras, but I cannot find anything saying this should be the case?
What app sharing method are you using?
If you’re sharing the same login credentials then you are restricted to a single login session at any time, another login will bump you off.
If you use the friend sharing you can have multiple friends at the same time unlimited although arlo has not specified what the limitations are.
Are you sure everyone is using their own (unique) account?
