How do I onboard the camera
Ho acquistato le Arlo pro 2 con la stazione (base) ma quando provo a configurare la base mi dice di connettersi alla sua rete Wi-Fi che però è protetta da password che non trovo da nessuna parte
What base model do you have?
The base is connected to your router via ethernet, and the onboarding process for the base doesn't prompt you to join the base wifi network. That network is closed, and only accessible by the cameras. The password isn't known/published.
Similarly, the onboarding process for the Pro 2 cameras doesn't prompt you to join an Arlo wifi network.
