  • 5 Replies
  • 3594 Views
Mojo40
The Pro 2 base station light is not green, not lit at all actually. I can still access recordings and live vision so its obviously got connection to the iternet. I thought if the centre light was not on then it meant no connection? I do have connection though?
Mojo40,
Typically, an unlit LED means there is no connection (no connection to the router or the internet). Did rebooting the base station as mentioned above resolve this or are you still experiencing this issue?
5 REPLIES 5
Streak2
Master Master
Use the power button the back to switch off the base and then after a few seconds switch it back on again.
steve_t
Master Master
I noticed mine was like that the other day. Then when I went back a few hours later, it was back to functioning as normal. No idea what that was/is about
Mojo40,
Mojo40
Well...after 3 days of having no lit centre LED, I went to reboot the base station this morning and to my surprise, the LED was lit. Not sure what is or was going on but its back on. Important to note that during this time the system continued to work perfectly.
Thank you to all the replyers and their assistance.
Mojo40
Yep..same for me but took 3 days to turn itself back on. Thanks for your help.
  • 5 Replies
  • 3595 Views
