If possible add enable pixel-based detection option to Pro 2 cameras. Make security easier!
  • 6 Replies
  • 2611 Views
Bryant101
As we all know the Pro 2 camera battery life isn't stellar and wiring exterior cameras to power can be a pain. Why not bring back pixel-based detection as an option? Of course allow for reduced sensitivity so every tree branch swaying in the wind doesn't set off the camera(s) but having cameras inside a house pointing out is SO MUCH EASIER! The current IR  tech does not allow motion detection through windows, very annoying. Man Frustrated
Firmware: Base 1.12.0.0_2709 Camera (H4):1.125.11.3_26229
Bryant101
Got a Q camera and appears to be working well through my windows (dual pane). A little fuzzy at night though but good during the day. Night vision and LED turned off.
6 REPLIES 6
If you want a camera inside the home looking out of a window, go with the Q camera... much better camera. IMHO, and has the pixel based detection you want. It works prefectly thru double pane andersen windows ( no ir of course )
Bryant101
I was just hoping to use my existing Pro 2 cameras. Looks like the Ultra is an option and hopefully these cameras can work with the Pro 2 base (one console). I am convinced Arlo removed the pixel detection to push more expensive cameras.
I see it as more of a power usage thing... pixel detect requires power ALL the time to function, it has to "see" to detect... something a battery camera can't do.  That's also why the extra options are available in the Pro2 when run on ac
Bryant101
Please enlighten me on what options are available when the Pro 2 is plugged in since I must be missing it. So far it appears the Q is what I need. Appreciate the info!
CVR, zones and 3 second lookback are available when the P2 is plugged in.
Bryant101
  • 6 Replies
  • 2612 Views
