I just purchased a new iPhone and I keep receiving the unable to add trusted device error. I thought this was resolved months ago. The device is completely new, not reloaded from iCloud and I made a unique name for it as well so there is no duplication.
Same error.
deleted old phone from trusted list. Cannot trust new device.
I can get into the app via not trusting, but the phone doesn’t ring when someone uses my arlo doorbell.
I’m having the same issue after upgrading to iPhone 14 Pro Max. It doesn’t automatically arm when I leave. I can’t set geo fencing on my phone etc.
I did that and it did not resolve the issue.
Still broken for me.
I keep getting the message that it does not recognize my device, I have clicked to send a push notification to my phone and my wife's phone but neither of us get a push notification. What the heck?
The 2FA will only allow one mobile device to receive the push request. If you’re old phone was set as primary in the 2fa list still then you will not receive it on the new phone until it is trusted and set as primary.
To get your browser trusted use email when given the another method option.
Same Issue New Iphone 14 ProMax. Only works if you "don't trust". Surprised that there are no solutions of explanation other than work around.
Still broken for me too. I upgraded phone and cannot get it trusted again. I deleted it from the web portal, but I get the same error still.
I AM IN!
I deleted the app from my phone.  Removed the old device from the 2FA screen on the website.  Logged back in on the phone tried to trust but it failed, clicked on Do Not Trust.  Went to the settings and 2FA on the phone.  Added the device in the 2FA section on the phone and it worked.  I am once again trusted.
This issue is not resolved and is a huge issue for this wishing to continue to use these devices!!
I am having the same issues when upgrading my phone and trying to trust as a new device, same error message appears. Unable to remove old phone from trusted devices list on web portal.
I am having the same issue with my new iPad Air 5, have tried all the workarounds people have suggested but still no luck and I can’t get a live chat because I don’t have an active subscription. This does not inspire me to do so. This is just stupid, I switch between my phone and iPad all the time, HUGE inconvenience.
I’m glad this worked for you, unfortunately it did not for me.
Upgraded to the iPhone 14 Pro Max today and returned the old devices. Went to login to Arlo with new device and it sent the one-time authentication code to my email (as my former device is no longer with me) and I was able to login. Then it promoted me to "Trust Device" which I clicked.
It did it's thing and came back and said this device can't be trusted. Arlo Chat Support is a bit perplexed and did all the basics, nothing is working. They think it's the fault of the app update, but I have seen others with the same problem.
Anyone know of any work around or help here? Thanks!
My new phone is an iPhone 12 and i have the same issue seems its not just linked to the new iPhone 14. I get the banner and it will not allow me to add it as a trusted device. I have had arlo since 2017 and back then when i had a an issue it got resolved quick. I also had someone call from California USA to me in the UK to help with my issues. They couldn't have been more helpful. I just hope this can be resolved fairly quick as it is putting us all in a highly vulnerable position. Please sort it out Arlo.
Just got my iPhone Pro Max, same here, cannot add this device as trusted from the app. Also I signed the my.arlo.com, however it would not allow me to remove the old iphone device from the trusted device list. Please provide solution. Thanks and Happy New Year.
I am having the same issue. current generation (2022) iPad. Will not let me add it as a trusted device. Get the same "There was a problem trusting this device" error that others report. The workaround of "don't trust" is no good, because it is a pain to have to re-authenticate via 2FA every time for a device that should be trusted.
After transferring all data and apps to my new iPhone 14 Pro Max, I tried to access the Arlo mobile app. A window opens where you can. “trust” the new iPhone. When I select “Trust”, I get a message that. “There was a problem, trusting this device. Try again”. I’ve tried again numerous times with no luck. Can anyone offer a suggestion?
Is this one of the features affected by the iPhones adoption of random Mac addresses?
Use private Wi-Fi addresses on iPhone, iPad, iPod touch, and Apple Watch - Apple Support
Just another user
I don't think so (random mac addresses are enabled on my iPhone 12 mini, and I don't have this problem). FWIW, the random mac addresses go back to iOS 14, so they've been in place for some years now.
Though it's easy enough to try turning them off.
Yes. And it is catching on. Windows now has an option for this.
Old it may be, but this "feature" continues to surprise people who have problems wit their wifi.
As you say, easily tested.
Just another user
Same issue here. 14 pro max.
I can get in after clicking don't trust device but this is NO SOLUTION. It's a joke that this is unresolved by Arlo for 3 weeks on the top of the line device.
Are you still experiencing this issue?
It happened to mine 14 pro max, and I selected “do not trust this device”. App runs for me. It is a work around only. Not sure why the Arlo Dev Team not fixing the issues.
Oh my goodness I can’t believe this string is 56 messages long impacting so many PAYING customers and Arlo are so poor at communicating progress on this issue!
Just let us know what you are doing?
The common denominator is an existing account and then a new phone - please sort! #iPhone
SOLUTION: delete the app from your new phone. Reinstall the app and you should be ok - you will be able to trust the device!
So simple! Feel a bit of an idiot!
						Arlo Mobile App629
						Arlo Pro 211
						Arlo Smart180
						Before You Buy996
						Features441
						Firmware Release Notes57
						Google Assistant1
						IFTTT (If This Then That)24
						Installation1,148
						Online and Mobile Apps865
						Service and Storage317
						SmartThings37
						Troubleshooting6,323
