I have a set of two solar Arlo Pro 2 cameras. One of the cameras is not recording and says battery needs a recharge.
Do I have to change the battery? How to get it ? Please advise.
What does that mean?
Two cameras with solar panels attached to charge their batteries?
Try charging the batteries before connecting the solar panels.
Just another user
The bettery was charged and the camera worked fine for almost a year and now i keep getting the message in my settings: battery needs to be charged. One camera is not recording and the other one is working fine. I do appreciate your input. Does this camera have a rechargable battery that needs to be replaced periodically?
Sounds like the battery just needs a charge...at times the solar panel may not keep it up fully. Plug the camera into the ac adapter for a few hours or if you have a spare battery , swap them and recharge later
