I Can't Change My Password On PC
I can't change my password (on a pc)
When I try to change to password to a new one it replies that "The new and the old one should be different" - And of course I'm trying with a different password. And I have also tried with different new ones.
What to do then?
5 REPLIES 5
Have you tried to clear your cache or try to change the password on a different browser?
Yes! - Have tried Crome and Explorer and same issue occors. Have also tried after cache is cleared.
Everytime and no matter which password I try is says "The new password and the old one should be different"
On the chance that the error message is too generic, you're not reusing an old password, are you? Try a completely new one.
I have tried with many different passwords. Still the same problem.
Would be great if Arlo could reset passwords
