Checking to see if there is any way to disable the sound for the cameras for ONLY the granted guest access, I would like to be able to listen to the camera sound and watch the video, but the others that I would grant access to, I would like to not have them be able to hear the sound, but still be able to view the camera video. Thanks in advance!
Refer extract below
“Friends without access rights can do the following:
• Play and view library content
• View live footage
• Zoom and drag video footage
• Control brightness
• Enter full-screen view“
The only way to almost achieve this is to turn off the camera microphone, but you will have to turn it on yourself when you want to listen in and then everyone can.
Best check your legal responsibilities with recording in public or workplace situations. No audio means no audio.
Refer extract below
• View live footage
Duplicated, and replied to, here:
How to shut off sound to guest access - Arlo Communities
Just another user
Thanks for your time, Dannybear!
