How to or can you disable 3 Minute look back feature in Arlo Pro 2?
3 Mintute look back feature is really good but it when its enabled the battery dies so fast. Is there a way to disable it, I know it stops working when its not plugged in but is there a way to disable it from the app? Thanks.
No...
