  • 5 Replies
  • 4267 Views
Samchong
Hi All, I purchased an Arlo Pro 2 system a few years ago and have not fully utilized it yet.  The system works but i want to know how to get the free 7 days cloud storage and can only find pay for subscription services on the Arlo site.  Can someone
5 REPLIES 5
dcfox1
You should have had it from the time of set up and still now for free 7 days.  Are you not seeing the recordings in your library? The subscription is for 30 day and smart notifications along with activity zones on battery.
Samchong
No i dont see any recordings and never had. Is it supposed to be automatically set up and included?  Thanks for the reply
dcfox1
Yes and you should have them even without a subscription on Pro2. Do you have them set up to record on motion in your mode then rules?
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
Samchong
I am not sure but i will check.  My kids set it up so i am not at all familiar.  In fact we just turned it all back on today.
Samchong
It looks like we got some action with setting up rules.  I will read the doc you sent and set it up properly.  Thanks alot,  i will update teh thread later.
  • 5 Replies
  • 4268 Views
