VMA4900 Micro USB replacement. What is green and white wire?
  • 1 Reply
  • 713 Views
depollack25
I need to put a new Micro USB end on my cable. The wire colors are not normal Green, White, Brown, blue and ground strand. What is what Green and white should be data?
Since the USB is only for charging, not data, I would suspect that the extra wires are either for additional physical support or possibly for detection of non-Arlo chargers. You're basically on your own here. You can use the Contact Support link at the bottom here for hardware issues, especially under warranty.
  • 1 Reply
  • 714 Views
