Hi,
I borrowed my daughters arlo baby camera and then bought the arlo pro 2. I don’t understand why the night camera in the baby camera is significantly better than the arlo 2 that is a security camera and more expensive ?
One is designed for indoors like a flood lights and the pro for max distance outdoors to a max of about 30 ft...
just a different design for the focal point ( not to mention a diff in wavelength)
But the difference is vast?
Hi Lion2012,
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Let me reach out to you via private message to gather more information from you.
Have you sent a private message?
Yes, I have sent you a reply back to your private message. I hope to hear from you soon through private message.
