  • 7 Replies
  • 1849 Views
Lion2012
Hi,
I borrowed my daughters arlo baby camera and then bought the arlo pro 2. I don’t understand why the night camera in the baby camera is significantly better than the arlo 2 that is a security camera and more expensive ?
7 REPLIES 7
One is designed for indoors like a flood lights and the pro for max distance outdoors to a max of about 30 ft...
just a different design for the focal point ( not to mention a diff in wavelength)
Lion2012
But the difference is vast?
Pro 2Pro 2Baby cameraBaby camera
JessicaP
Hi Lion2012,
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Lion2012
Hi, I have contacted them and had no response !!
JessicaP
Let me reach out to you via private message to gather more information from you.
Lion2012
Have you sent a private message?
JessicaP
Yes, I have sent you a reply back to your private message. I hope to hear from you soon through private message.
  • 7 Replies
  • 1850 Views
