  • 14 Replies
  • 3740 Views
John-srq
My VMB4000r3 with Arlo Pro 2’s are stuck in “discovering devices” and I’m unable to get them in HomeKit.  Can someone assist?  All firmware is up to date.  Thanks in advance.
14 REPLIES 14
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
How do I connect my Arlo device to Apple HomeKit?
John-srq
BrookN - still does not integrate with HomeKit.  Followed instructions; twice.  Firmware is 1.21.1.0_4302_9611cf3
and iOS 17.0.3 on a dual band Spectrum router.  Shows “Devices Found” but just clocks and times out.  Any ideas?  Thanks.
BrookeN
Please try the following:
Setttings>Privacy & Security>Homekit
There you should fine a listing of all the apps that have requested access to HomeKit.  Slide the bar left (off) and back to on (right - green).  Then go back into HomeKit and check your device(s)
It appears that when you originally authorized the app to HomeKit it generated a certificate (for security purposes).  The sliding of this bar off and no seems to regenerate the certificate.
John-srq
That too was unsuccessful.  Can I remove the VMB4000 from the Arlo Secure App, perform a factory reset and then re-install the base and Pro 2’s to my account?  Would that help?
BrookeN
Let's try that, I am going to reset the token one more time and then do the steps you mentioned above.
John-srq
It worked with the factory reset.  Re-syncing the cameras was a pain but all is good.  Thanks so much!
BrookeN
Perfect, I am glad it worked!
tdevitojr
I cannot connect to Homekit with the Same Arlo 2 Pro system. Please resend a token reset to my system for assistance.
BrookeN
tdevitojr
Unfortunately, that didn't work. The "discovering devices" portion is now not doing anything once I click on Homekit in the app. Previously, it was just spinning.
For what it's worth, I'm on app version 4.9.1 (6960)
BrookeN
I am going to reset the token again. Before resetting up the device, uninstall the app and reinstall it. Then reboot the base station and follow the steps that I sent in the link.
tdevitojr
Hi,
I followed your instructions and I’m still getting the Discovering Devices screen after selecting HomeKit and it doesn’t do anything from there.
BrookeN
I have reset the token again, however you will need to reset the base station.
https://kb.arlo.com/1057976/How-can-I-factory-reset-my-Arlo-SmartHub-or-Base-Station
tdevitojr
That got everything working. Thank you for the help!
  • 14 Replies
  • 3741 Views
