  • 1 Reply
  • 1726 Views
Leethi
Hi how do i set up schedule on each camera i want one camera to be on always and i want one to be on only at specific times and i have also tried creating Custom Modes but second mode setting is replacing the first mode setting
It can be done.... but you must break up the cameras into groups ( as needed ) so you can schedule multi modes
exp ; you have cams A,B, C
this can be made into modes for ALL cams ( ARMED), AB, AC,BC, A,B... ( make the groups as you need )
Then in the schedule for each day use the mode you want for the time frame.
Tips:
Only one mode can run at a time ( as you know )
Any camera not in the active mode is OFF
If you run thru midnight, break the time into 2 parts : up to 1159pm then restart at Midnight the next day
For multi camera mode, create the mode for the first cam ,save, then go back and edit to add the others
  • 1 Reply
  • 1727 Views
