Hi,
I hope someone could help me with the issue I am facing. I have a 4 cam Arlo Pro2 setup and I use the Geo-fencing mode where Home=Schedule(Armed at night) and Away=Armed. I have added 2 devices (My iphone and My wife's iphone) for geofencing. Both my devices don't have any special characters in the device name.
Everything was working perfectly until last week where the Geo-fencing literally stopped working.
1) While both devices are actually away from the fence, my device would show as 'Out of zone' and my wife's device will show as 'In zone'. Google maps and even Arlo's gefencing map shows my wife's device is out of fence, but the status still stays as 'In zone'.
2) To workaround, I removed my wife's device and added back. This did not work. So I tried removing my wife's device. Now the status of my device is 'Out of zone' but when I enable geofencing and I am actually out of home, the mode gets changed to Armed and immediately switches to Disarmed.
3) While I am at home, the schedule does not turn on.
Can anyone help me out with this issue? This is so frustrating as I have to manually enable and disable modes.
iamcrd,
Consider refreshing your enabled devices within Geofencing settings. Disable all listed devices, save and then enable the devices again.
Log in to your Arlo Account (the primary) and navigate to Mode > select your Arlo system > edit Geofencing > click "Enabled devices". Toggle all of the listed devices off and save. After you have finished saving, navigate back to "Enabled devices" and toggle all desired devices back on and save.
Hi JamesC,
Thank you for responding. Yes, I tried this obvious workaround and this is how it works for me.
1) Disable all devices
2) Enable primary and set geofencing on
3) Enable secondary while geofencing is on
After the above, the geofencing works for a day and again goes into limbo. And it always is due to secondary device. I am having to repeat this workaround every alternate day. And I can confirm that every setting,device name,etc is fine on the seconday device. Looks like geofencing stutters with multiple devices. However, everything was fine until few weeks ago.
Pro2, 5 cameras, two iPhone 6s., geofence set to small, no special characters in names. On phone with Netgear tech support level two today, they admit widespread new recent problems with their geofencing. No resolution other than “they are working on the known problem”.
Having to manually select armed and disarmed is really frustrating.
Really regretting buying these...
- RChobby, could you please explain a bit about life360, and ifttt? I don't know what they do, or why needed. Thanks
I also made two more ifttt applets, to put “buttons” on my “today” screen on the iPhone (left swipe from home screen). One button is to arm arlo, one to disarm. Very nice to not have to open the Arlo app to arm and disarm. Very fast and convenient.
Thanks for the help RChobby. The ifttt app looks good, have it running now. I can't find life360 on the App Store, just "life360 church" , "life360 magazine", and a few others with similar names. Doesn't look like any of them are the one you're talking about.
Ok, thanks. I'll look for it right now
Got it
