Arlo pro 2 are showing offline
My arlo pro 2 cameras are showing offline they both are well inside the range of wifi and both are over half way charge
Bit annoying for a £660.00 camera system
not happy
Same here. Went down last night and both my Arlo Pro 2 cameras say they are offline. They are both plugged in and my internetet connection is working fine. But base does not show connected ( center light off) Before I go through a time consuming troubleshooting and find out it was a problem with ARLO servers I'm holding on for answers here.
Same thing happened to one of my camera just now. Over 75% power on battery and just went offline. Only have had it New from store for a week at most.
What do the LEDs on the base show? Have you power cycled the base, reinserted camera batteries and maybe tried to resync the cameras?
It keeps showing offline which is no good if someone is wanting to break in my car or house and the cameras are offline
Base station light all correct and other camera was fine. Pulled battery and nothing. Did a resync with the base station and it came right back up with all the settings in tack and battery still right where it was.
Someone checking car doors in my street last night and guess what my cameras was offline absolute joke
Neighbours £180.00 system picked them up and my arlo pro 2 system never
I've paid a premium price for a product thats not worth it
What a joke
I've been seeing this all morning too. I refresh the site and things seem to come back online after a fresh login. Netgear having some authentication issues again?
Sounds like it's a Cox ISP issue.
I’ve been having the problem with mine through he mobile app.
The base connects to the existing network and the cameras connect to the base.
@Junca wrote:
New system and cannot sync cameras. Do the cameras connect to the base or to the existing home wi-fi?
How are you trying to sync? Press the base sync button only briefly - don't hold it. Then press the camera sync button. You should see a slow blue blink on the camera followed by rapid blue (success) or amber (failed) LED.
