  • 1289 Views
Crispyswan
My dual charging dock is crazy.
Symptoms:
Lights turn yellow upon inserting battery. Within 10 secs turns off. No green light or anything.
I got that far by using a suggestion from another forum post; I unplug the charger and upon plugging in the charger I inserted the batteries within two minutes.
Batteries charge fine in the devices.
JessicaP
Hi Crispyswan,
Is this happening when plugging in to a different power outlet?
Crispyswan
It happens using any outlet. I also tested both of the cords and AC adapters that came with my kit from Costco.
JessicaP
I would suggest contacting the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
  • 1290 Views
