  • 2 Replies
  • 3598 Views
Earlyriser2
I just installed the cameras and now the alarms go off. How do I disable them? Thanks
What alarms? The push and email notifications or the siren? Either way, edit your modes (there are FAQs here with complete directions) and disable whatever you don't want.
steve_t
Master Master
As above, the rules in your mode have the option to enable or disable the base siren from sounding upon motion detection. You sould like you need to edit each rule and ensure the box is unchecked. Definitely have a look through the FAQs and user manual for the system to help you familiarise yourself with how all the settings affect things and how to configure all the modes and rules that will suit your needs
  • 2 Replies
  • 3599 Views
