Hello. I understand that continuous video recording (CVR) is an option with the Arlo Pro 2. But I have two questions regarding this option:
1. Is it possible to continuously record using only the basic 7-day cloud storage plan? So, in essence, it would continuously record to the cloud and continuously rewrite over the stored video from 7 days ago. Or is it required to purchase the upgraded 14-day or 30-day storage plan if I want to continuously record?
2. On the website, it says that CVR is available for indoor recordings only. If this is correct, then outdoor cameras cannot continuously record at all?
Thank you.
CVR is a separate subscription which will work with any camera that has AC power applied. It won't work on battery power since the battery would die quickly. If outdoors, be sure to use the outdoor power adapter.
