Hi, I have a Pro2 set(PN: VMS4230P-100EUS). I used it for a few months, then I give them to a friend of mine. My friend creat a new account and added the device successfully, but the cameras cannot record video by Armed with motion detected. Cameras' Motion Detection Test is OK.
And I have reset(press and hold that little hole) the base. And take out cameras' batteries. Still not work.
What are the LEDs on the base showing? DO you see all devices (base and cameras) in Settings, My Devices as well as on the Devices tab?
Hi, there are 3 green LEDs bright on the base. I can see all my devices anywhere, and I can even test their motion detection successfully.
Have you try to do manual record to see that works?
Live is works, but no video recorded after I pressing the record button.
Did the live view showing being recorded at all? you should able to see a time related on the video while recording? You will see how long is being recorded also.
Are you using the Armed mmode or a custom one?
The video can be recorded, there is a timer running while recording, the videos also appear in Library, but the video file is not created on the USB storage drive as usual.
Need details starting with what the LEDs are showing as well as what mode is selected.
@jguerdat The three LEDs are all green and the middle one is flashing when I selected Armed mode.
This seems to have multiple threads merged. Please restate your issue so I'm sure of what we're talking about. 3 green LEDs is good.
Hi, I didn't do anything, but they came back, you modified the bug in the background?
Thanks all the same.
