Can't use two way audio at the mmdmt
  • 6 Replies
  • 1316 Views
Teej107
Keeps saying 'connection failed' when I try to use the push to talk audio option. The camera is online and working except for the audio function
6 REPLIES 6
If rebooting the phone and reinstalling the app doesn't help, try reinserting the battery to reset the camera to a known state. If that also fails, I'd remove and resync the camera.
ShayneS
Are you still experiencing this issue?
Teej107
Yes I am unfortunately
ShayneS
Does the same occur on mobile data/wifi and web portal on a pc?
Which version of the Arlo app are you using? and which version of OS on your phone?
Teej107
Thank you. Updating the app sorted the problem. Didn't even think about doing that. Thanks again
ShayneS
Awesome, let me know if you have any other questions.
  • 6 Replies
  • 1317 Views
