Can't use two way audio at the mmdmt
Keeps saying 'connection failed' when I try to use the push to talk audio option. The camera is online and working except for the audio function
6 REPLIES 6
If rebooting the phone and reinstalling the app doesn't help, try reinserting the battery to reset the camera to a known state. If that also fails, I'd remove and resync the camera.
Are you still experiencing this issue?
Yes I am unfortunately
Does the same occur on mobile data/wifi and web portal on a pc?
Which version of the Arlo app are you using? and which version of OS on your phone?
Thank you. Updating the app sorted the problem. Didn't even think about doing that. Thanks again
Awesome, let me know if you have any other questions.
