  • 10 Replies
  • 4267 Views
WhiteLightning
Newly installed Pro 2 system constantly records my two dogs as they move about near the house while we are away. The Smart Premier software is pretty accurate at identifying them as animals so I thought it would be possible to change settings to ignore them but I have not found a way to do so. Is this not possible?
My concern is that the battery life will be dramatically shortened and the camera positions are not easy to wire.
Am I correct about the constant triggering draining the battery?
Any creative solutions that don't involve aiming the cameras somewhere else?
10 REPLIES 10
brh
@WhiteLightning
See what happens if you turn the Animals slider switch off. It is advertised to help prevent false triggers.
Brian
brh
@WhiteLightning
Out of curiosity, do you have Packages option. Mine doesn't.
Brian
WhiteLightning
Best I can tell that only disabled notifications and doesn’t stop the recording
WhiteLightning
Yes it is shown below smart notifications and has a Beta tag
brh
@WhiteLightning
That is what I was afraid of. But at least it the notifications are turned off for them then you won't be getting tons of false notifications.
My thinking may have been wrong on the package detection. I put one camera as active but when I went into Settings > Manage Arlo Smart then looked at each active camera, all I saw was 4 slider switches:
People
Vehicles
Animals
All Other Motion
When I did not see a slider switch for Packages, I assumed it wasn't working. Maybe just having one camera selected as active in the Package Detection section is all that is needed to make it work.
Brian
dhiller0217
It is not working properly, and they need to address this among many other things.  Yes, it is draining your battery for no reason at all. In the attached, you can see that I have actually DISABLED Arlo Smart for every one of my cameras, yet I am STILL getting "smart" detection.  I used one of my cameras as an example, but every one of them are detecting my pets, people, general motion, vehicles, and whatever else.. Also, there's delays in the notifications which vary from 10 seconds to 30 minutes on my Galaxy S9, there's DOUBLE notifcations for any activity, and there's no still image of the activity on my lock screen until after I log into the app on my phone, which makes even receiving "rich" notifications pointless.
brh
@dhiller0217
Out of curiosity, did you also turn off the slider switches for each camera. Someone said doing that brought back the speedy notifications.
Brian
dhiller0217
Hey Brian, yeah I did turn all the sliders off before removing the cameras from Arlo Smart, but I appreciate the response. Really though, we shouldn't have to find so many workarounds for all these flaws. For months I have been going through like a 12 step process just to install new versions of the app and not get duplicate notifications afterwards, and now that doesnt even seem to be working either. It's ridiculous. I could write a book about things that are not working properly, and they have all surfaced within the past 6 months or so.
brh
@dhiller0217
LOL. Don't get me started on these messes by Arlo.
Brian
Jbsox
I am having the same issue.  I have the Arlo Pro 2 with 5 cameras mounted outside.  I live on 3 acres and have 3 dogs from 60 to 80 lbs. I am paying for the Smart Plan which they told me would allow me to turn off pet detection.  I have been playing with the motion sensitivity under the mode option, per instruction but it makes no difference.  It doesn't work.  If I get it set low enogh not to pickup the dogs...it doesn't pickup me pulling the car in the garage.  I opened a case on Monday 12/24 and was told it would be escalated to Level 2 support.  I have called back twice and still have not talked to anyone at level 2 support.  I was told they are very busy with everyone who bought cameras over the holidays.  Grrrrrrr
  • 10 Replies
  • 4268 Views
