My cameras have all of a sudden become more sensitive and are picking up things blowing on windy days. I have decreased the sensitivity way down and it still is an issue. I finally just have to disable them so batteries won’t die from all the false triggers. Very frustrating. May switch for Ring cameras which are much more user friendly in that regard and have people only mode.
As the sun's angle changes, so does the reflection of it's IR output. Be sure to reduce your sensitivity using modes and rules, not the motion detection test. Repositioning your camera(s) to avoid the problem areas may also be useful.
If you have a subscription (or if the camera is AC powered) then activity zones can also help.
Though there are some times of the year when some of my own cameras behave this way, and the best way I've found to reduce the notification flood is to use smart notifications (turning off "all other motion", and perhaps some other classifications).
