Camera turned off
Hi Guys,I have my Arlo turned off but it keeps Detecting motion and Recording.
How can it work when it’s turned Off?
Do you have rules that use one camera to detect and another to record (nested rules)? That seems to be normal operation although not expected. I assume you're using the On/Off switch for the camera rather than the Disarmed mode? Use of the Disarmed mode (or a custom mode that doesn't use the camera you want off) should work for you.
stig6,
As jguerdat mentions above, how have you "turned the camera off"? Are you using the on/off toggle in camera settings or are you using a mode that disarms the camera (default or custom)? Please give us more details on what you are experiencing.
