Well, I WAS going to buy an Arlo .....
Well, it was going to buy an ARLO PRO 2, but just a glimpse of all the problems people are having makes me look otherwhere. The features and specs look great on the box, but if they are troublesome or not true to spec, why bother. All the issues with connections and POOR night video...etc.
why would anyone spend hundreds of $$$ on a product that the company does not back, or at a minimum COMMUNICATE with the consumer. All the rave reviews on Amazoon and other major sellers looked great in the beginning but even they are starting to dwindle. Thank goodness I came to this forum.
Netgear, back your products and communicate with the consumer.... and you will sell at a rate that you won’t be able to keep the ARLO on the shelf !!
Pss3757,
The engineering team is actively investigating the concerns being discussed here on these boards. As soon as I have more information on each topic, I will provide an update on the appropriate threads.
