Camera shows only black and white video. Even live, in broad daylight. It also records no movement unless the object is within a few feet.
Hi Sikorskidp,
Try to clean the camera lens and sensor to see if that helps. Otherwise, try to remove the battery off from your Arlo camera completely and re-insert them back in.
That did not work. I am also now encountering a new problem. Both my outdoor cameras are connected to a solar panel. Both have worked fine for over a year. Now one camera gives me the message, Power source not compatable, and the camera battery drains in a matter of days.
Here's some advice on the issue with the panel: https://community.arlo.com/t5/Arlo-Go/Arlo-Solar-Panels-showing-quot-Incompatible-charger-has-been/m...
