  • 8 Replies
  • 1497 Views
  • 5 In Conversation
Lalbe
Hello, Camera will not record or detect motion . Live works . Any suggestions? Sometimes it randomly will start detecting but then when I change the battery it stops detecting.
@rlh72152 wrote:
Not sure what that mean?
The mode you are using is selected on the dashboard.  It is shown in color, the other two are gray.
I am wondering if you have the system in "Standby" - which is the same as "Disarmed" in the old interface.
Another possibility (less likely) is that Arm Home and Arm Away are not set up to arm your cameras.
8 REPLIES 8
DannyBearAgain
Always check that motion detection is working correctly after changing the battery.
To fix, remove the battery again for 10sec and insert again. Resets the camera .
If that fails to resolve then perform a camera resync by momentarily pressing the base top sync button then do the same for the camera top sync button to resync the camera.
BrookeN
@Lalbe are you still seeing this same behavior?
Lalbe
Yes, Camera still will not detect motion.
First, confirm that you can make a manual recording while Livestreaming the camera.
If that still works, then try the motion detection test.  (Go into the camera settings -> default mode settings.  You'll find the test there).
rlh72152
I have the same problem with 2 Pro 2's.  I had cameras in standby for several months.  batteries were low, so i changed the batterys.  Now they won't detect motion.  the work in live mode, and i have tested for motion detection and the amber light flashes with motion.  But the cameras will not detect and record motion.
Richard
Have you double-checked the camera rules in the mode you are using?
rlh72152
Not sure what that mean?  i didn't do anything except change the batteries, and now they won't detect motion.  i have seen the occasionally over the years and if i put in a different battery, it always went back to working.  Not this time!
  • 8 Replies
  • 1497 Views
  • 5 In Conversation
