Camera not charging
One of my camera installed less than 3 months ago is now not charging any more (charge icon not displayed in application) while solar panel VMA3600 is plugged and sun shining. Every day charge is lowering currently at 60%
In camera settings, an error message says « Impossible to charge battery, connect a charger »
First thing I would do is check that the connection is good....
Take it down and/or unplug and re-plug the cable in a few times to see if the contacts get wiped clean.
check for function
If possible and you have a voltmeter, check the output of the solar panel for output at cable end.
I don’t have a voltmeter to test the micro-B USB. I charged sucessfully to 100% with charger and yet the error message says charging is impossible after plugging back solar panel.
Which arlo app are you using, website, android or iPhone?
@Dannybear Arlo app on iPhone.
I asked since the web and android apps have had issues with displaying battery info.
If you can remove the solar panel you could look for water ingress, do you have another camera to plug the panel into?
Also check for rodent damage to cables, all my outdoor lights died over night because a rat didn’t like the cables in his way.
@Dannybear I will swap cam’s tomorrow to see what happens
