Hello,
*I have my system adjusted to the most sensitive setting. It picks up cars driving by, but not people walking by or into the driveway. The road is about 30 feet away (picks up every car driving by). Additionally, I have noticed it does not keep recording when there is movement - I am talking about movement that is even closer, 15 feet or less, and directly on the porch in front of the camera.
*The camera is set up to keep recording until the movement stops.
*It is plugged in, so it is not a battery issue.
*I had to reset the whole system a few months back, and that did not correct this problem.
Anyone have any idea? Is this fixable, or just a product flaw?
First, the PIR device that detects is good for people to 25 ft or less...cars a bit more as they reflect mor ir.
Second, I never found the “record till motion stops “ to work well for me...if the cam doesn’t see motion it shuts off. Always found a fixed time to perform better.
If you want to cover the street 30+ ft away, it prob not going to work well.
But the Q camera with pixel detection ( over pir ) in my window get every car and person at 50+ ft..... so it’s more design
What is a Q camera?
Don't forget there is a reset time from one trigger event to another....
So, after the camera sees no motion it stops recording and then may take up to 20 secs to reset ( so no recording ), which is why I recommend a fixed time of 30 - 60 secs.
Q cam;
https://www.arlo.com/en-us/products/arlo-q/default.aspx
https://www.amazon.com/Arlo-Security-Storage-Included-VMC3240/dp/B01G7JERCY
