I've swapped the camera but it's still occurring.
Can anyone advise please?
Dave
You may have the AUDIO trigger set too...
you can have motion, audio, or both set.
Edit the mode to toggle off or turn off mic in settings
Audio not selected (or I wouldn't have raised it as a concern).
The actual notification states motion detected and so does the recording.
This is what's so confusing.
I thought there may be vibration through the camera but is 6 myrs away mounted to the main gable end of the house so it's a firm base.
D
Since you already swaped the camera and it still occurs, it must be the location.
some how the IR of the roadway/vehicles is being reflected or the PIR covers more than the FOV
Only option may be to temp move the camera ( or fov ) and see if it continues to confirm same
You could also try to turn down the sensitivity of the motions and see if this reduces notifications during heavy traffic.
Yes I have reduced the sensitivity to the bare minimum but can't go further as it won't cover my door to the house, which does seem to have reduced the false alarms.
But why is it even detecting sound on a PIR I've never experienced this with any other PIR triggered equipment such as lights and intruder alarms?
That means your modes and rules have audio detection enabled. Edit them and deselect audio detection. The PIR doesn't do that, the mic on the camera does. I know you have said that audio isn't selected but it must be. Post a screenshot of your rule if that's incorrect.
Not sure what you mean reference rules.
The audio is off on the cameras and when it triggers both the notification and video clip state motion detection?
D
"Reference rules?"
Where is the audio turned off? It's not in your camera settings, it's in your modes. I have a feeling you're changing things in the settings and not in the rules. Read the FAQs here on changing sensitivity and other settings if you're not familiar with this.
Perfect! That proves you have audio disabled. However, you say that the videos are noted as "motion" - if it was due to audio, that would be noted as such. Why are you sure the videos are somehow being triggered by audio?
The notifications state motion and the video tags state motion but the only constant is a noisy large vehicle passing out of shot and some 6mtrs from the camera position.
It's very puzzling but obviously very annoying also.
D
My guess is that the large vehicles reflect the sun's IR in large amounts. This could be reflecting off other objects causing the detection. Does this happen on very cloudy days or at night?
Post a link to one of your daytime videos (in the Library, select a video and use the share icon to copy the link and paste it here) so we can see/hear. Maybe that will provide a clue.
I still don't understand why, as the detection was nowhere near the road but seems to have worked.
Thanks for all your input
D
The reduction of PIR sensitivity seems to have done the trick but strange as the detection done was some 3-4 MTRS from the road and the road was not in the field of view of the camera.
D
