  • 8 Replies
  • 3671 Views
CRPowell
I have two ourdoor cameras which looking at the image it appears as if everything is under a bright light. evewn in a cloudy morning withiout sunshine. I have brought the camera inside and again everything appears very bright. Any ideas or help
8 REPLIES 8
AncientGeek
Hero
Hero
Is the protective film removed from the lens?
CRPowell
Thanks for responding, Yes the film has removed. the cameras have been in their positions for several months and started this a couple of days ago.
AncientGeek
Hero
Hero
Wow.  I have had one or more cameras start to display a bright green pixelated image from time to time.  I retired the cameras.  I’ve not seen what you are describing and nothing recently.  Have you removed the batteries and restarted the base station?  Arlo equivalent of Control-alt-delete.
Might also be worth removing the camera from Settings, My Devices and resyncing it.
CRPowell
thanks,  I tried the two procecdures, still having problems. I have 5 cameras and only two are having the problems
Use Settings, My Devices, your camera, Video Settings to adjust the brightness for the app. For a browser, use live view and then the sun-looking icon to change the brightness. Be sure to save the setting.
CRPowell
when you retiired your camera did you contact Arlo for a possible guarantee or refund? or are we all just out of luck and have to buy new cameras?
AncientGeek
Hero
Hero
I think I returned one camera that failed fairly quickly, but I've not tried to return cameras that I've used for a year or more before they failed.  I have some with green images and at least one Pro with noisy audio.  I retired some original Arlo cameras when I installed Pro or Pro 2 cameras, so I have a drawer with a half dozen or more semi-usable cameras in it.   Sometimes I grab a camera to use as a second set of eyes when doing tasks around the house....like pulling cable and needing to monitor the other end.  Or flipping breakers and watching for a light to go out.  Monitoring a mouse trap.  They can be handy for odd tasks.
  • 8 Replies
  • 3672 Views
