Woke up and noticed my Base Station had gone offline. Like gremlins tampered with it during the night. 🙂 Was fine when I went to bed. So far I’ve turned it off and on, removed and re-instated it, unplugged and re-plugged cables following ‘Troubleshooting Guidance on Arlo Web Site to no avail.
As a last resort I’ve even reset it back to factory default, still no joy. The power light is solid green, Camera light is blinking green. Internet light is out completely. When I power cycle the base station, the internet light comes on (solid green) but then goes out again immediately. I have various other devices on the same Wi-Fi Network and none of them is having connectivity issues!!!. Model VMB4000r3,
Any ideas?? Thanks in advance
UPDATE:
After fiddling with cables, plugging and re-plugging, removing and re-adding device again and again, the Base Station finally “found” the network and I was able to sync 2 other cameras to it.
However, when trying to sync 3rd camera, got message that Base Station was “offline”. Check internet connectivity status and this time, there is a green solid light. But still unable to add 3rd camera as I keep getting message that base station if offline!. Oh well...
UPDATE:
