Hi,
My base station an cameras are off line on the app. The base station is showing 3 green lights and internet is fine. Tried a reboot and turned router off and on. Nothing works. Help appreciated.
I would try and reset the base. and reinstall from scratch.
https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-base-station-to-the-default-values
Message 2 of 4
1,428
Message 2 of 4
1,429
Thanks. I'll try.
Message 3 of 4
1,418
It worked. Thank you.
Message 4 of 4
1,394
