After the last upgrade the base station became unstable, going offline and having to reboot it to get it working again.
now it won’t even power up, no lights on. I have put a tester on the power supply and it is working giving me the required 12v
i have unplugged the base station, reset it etc, doesn’t switch on?
What is the power LED showing? If anything but green, it's not gonna work. Open a case with support here:
No green power light. Have logged a fault with arlo support got a confirmation back promising a 24 hour response and have now waited 5 days, no response?
Tickle 'em back. Don't let it go on and on.
Have got a ticket 40569820 generated by a user on my behalf but have never been contacted by anyone Not very satisfactory
You can try the Hard Reset, but if your not even getting lights it sounds like a faulty base station. If you have not done so try the Hard Reset any way; you never know until you try. If still nothing call Support back.
How can I reset my Arlo base station to the default values?
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
