Re: Arlo pro 2 not recording or alarming
- Email to a Friend
On of 2 cameras has quit alarming and recording. Using the free software
- Email to a Friend
You won't believe this. I did the resyncs on Saturday and today it's working!! Amazing. Just took a mention of calling support and whammo it's behaving now!
All Replies
- Email to a Friend
Details. What have you tried? What do you see? Are the motion indicators (3 lines and a dot in the app, running men in the web browser) in the Devices tab gray or black? Gray means disarmed - check your active mode.
- Email to a Friend
Both camers are armed. The 2nd camera is fine. I have turned off the camera and turned it on via the app. I will check for the lines and get back to you in a little bit.
- Email to a Friend
Have the 3 lines and dot.
- Email to a Friend
But is the icon black or gray? Gray means the camera is disarmed.
- Email to a Friend
@jguerdat It is black. My last reply must not have made it to you. So do you think a rsync on that camera would be helpful?
- Email to a Friend
That would be a good first step.
- Email to a Friend
Great I will do that when I get to dad's. probably tomorrow or the next day.
- Email to a Friend
No luck. Now the blue light in the front is not on either. I do still have black lines with the dot. The 2nd camera has amber lines and dot but still records and alerts
- Email to a Friend
Ok 2nd camera has black lines and dot and alerting and recording. 1st camera no light and no alerts or recording. I have synced several times. 1st camera still has the black lines as and dot. I can manually record.
- Email to a Friend
You may need to open a case with support for a bad camera:
- Email to a Friend
