WHat mode are you using? Have you checked the settings in that mode?
Yes and created a new mode I’ve literally done everything you can do through technical support multiple times and nothing continues to work they might work for a few times then go right back to not recording or sending notifications also my app isn’t working properly to look at new videos recorded if any actually record I have to sign out of the app and re sign in . I’ve owned these cameras for awhile and I never had to do that it’s like the system needs an update but there’s no update to download and the status on there website is fine . Very frustrating had to return a bran new 4 camera ultra system as well because it was doing the same thing and my internet connection is stellar so that’s not it either . I don’t expect this to just fix itself so if problem persist I will be throwing out this system and purchasing a different brand .
