One of my ten cameras stopped recording.
I have removed the camera battery. Then deleted the camera from the system. Put the battery back in. Add the camera back. Still nothing
I have removed the camera from the system first. Then taken the battery out. Put the battery back in. Added the camera back. Nothing
I unplugged the base station and let it power up. Nothing
I have pressed reset on the base station. Nothing.
I have reset the base station through the app. Nothing.
The camera recorded fine for a month or so.
I do a motion test and yellow light comes on.
I can click on live feed and it will show me a live view.
How do I fix this? The other 9 are recording fine.
Test the camera 1) with battery out and running on ac only 2) test with a diff battery
It may be just a bad camera...if so contact Arlo support for possible warranty
