I have a pro2 camera wirded on ac wich recordings worked goed until a few weeks. Sometimes when playing back recordings i noticed the movie freezes but the sounds recordings walk true. So you can first see someone walk then the person freezes en th sound go's on. So sounds telling that someons walking but the film shows that the person freezes.
I have three camera's this is the only camera showing the problem.
I'm on the latest firmware.
Hope you guys can help me out.
thank you
most likely is that the signal at the camera is weak, Your internet speed is too slow or there is interference between the base and the camera.
What is the signal strength showing on the camera?
What are you download and upload speeds for your internet? If you don't know, you can download the Ookla Speedtest app and check the speeds while standing near the camera.
Temporarily move the camera closer to the hub and see if that fixes the problem.
Brian
Hi signal is always two bars. Speed is download 204mbit and upload 21 Mbit. So I doet think thats the issue.
kind regards
Brian
@Dannybear wrote:
If you have the USB backup installed, check to see if the recordings also has the same issue.
Dont have USB, So cant check that.
My experience is that this a common theme in that your recordings are perfect on the USB but the cloud server only records part of the video stream.
As the audio stream is still recording to the cloud this eliminates the internet path and as the USB recordings are fine the wifi path is fine also.
This defines the base station as the issue and likely to be a firmware bug.
This issue has been about in the forum for a long time.
I no longer have the issue since removing the pinch and zoom settings on all my cameras.
Hope this helps.
hmm hope netgear wil fix this, because one of the reasons i bought this setup becaus it was easy in use
then i hope dat arlo fixes this issue 😉 if i put in a usb what capicity it should have? and wil it also automaticy delete's in a week?
I have never used a mechanical HDD so not sure if there’s sufficient power delivered from the USB port. FAQs can help.
I use two 16Gb flash drive sticks, one per port. The format requirement is FAT32 which most are already out of their package.
Set the backup USB option in the App to not auto overwrite so you get an alert when the active usb is 80% full. Then you can manually select the second USB drive and then eject the other drive for archiving. If you set overwrite you will never know when they are full.
You can just keep buying new ones to add on or copy the recordings using a PC, clean the drive and insert back into the base.
I renamed my USB drives to match their colour so I know which one to eject for archiving.
Be aware that you can’t manually record to the USB, only to the cloud library. If you opt for CVR recordings you will not get these on the USB backup either, neither detected recordings.
The amount of time it takes to fill my drive is about 3 months with moderate use.
Also be aware that powered cameras will not properly record to the USB if you loose internet to the base. Arlo acknowledged issue with the base firmware.
Regarding the fix, the more users complain to arlo management the more chance it will be considered.
Each drive can be 2TB but that's because the ultimate limit for FAT32 is 2TB. That's rather gross overkill for many users - 16-64GB should be plenty and can be handled by cheap thumb drives.
