Arlo pro 2 Hub with latest firmware won’t format Seagate ultra slim 2T portable drive.
I have noticed that it is not possible to format drives larger than 32GB on the base station with the newest firmware. This is just a warning for everyone who googles this problem. Also, since windows prohibits formatting fat32 drives larger than 32GB, you will have to use a third party formatting tool to do so if you wish to use a larger drive.
Can't format drives larger than 32GB - Arlo Communities
Just another user
FWIW, you can format larger drives with fat32 w/o a third party tool - but you do need to use the windows command prompt. Run it as administrator. The command is
Format /FS:FAT32 X:
Use the actual actual drive letter of course.
