Arlo pro 2 Hub with latest firmware won’t format Seagate ultra slim 2T portable drive.
  • 1900 Views
CheriA
Says ready to format but then stops after it starts saying it cannot format the device. Can’t format FAT32 on PC because Windows 10 limited to other formats.
MegaTronJr
I have noticed that it is not possible to format drives larger than 32GB on the base station with the newest firmware.  This is just a warning for everyone who googles this problem.  Also, since windows prohibits formatting fat32 drives larger than 32GB, you will have to use a third party formatting tool to do so if you wish to use a larger drive.
michaelkenward
Sensei Sensei
Sensei
Can't format drives larger than 32GB - Arlo Communities
Just another user
FWIW,  you can format larger drives with fat32 w/o a third party tool - but you do need to use the windows command prompt.  Run it as administrator.  The command is
Format /FS:FAT32 X:
Use the actual actual drive letter of course.
  • 1901 Views
