  • 7 Replies
  • 1383 Views
Mikica
I have Arlo 2 cameras connected to Arlo Ultra base station, all works ok on iPad an iPhone but I have changed phone to Android (Xiaomi Mi 9T Pro) and now they are all the time offline (while if I check on iPad, they work and they are visible)
7 REPLIES 7
JessicaP
Hi Mikica,
Are you using the Arlo Legacy app or new Arlo app? Have you tried reinstalling the Arlo app and rebooting your Android device to see if that helps?
Mikica
Using new app, and reinstalled, rebooted, cleared cache...
JessicaP
Is this happening when you're on WiFi and/or cellular data on your Android device?
Mikica
Yes, it is the same on WiFi and cellular
JessicaP
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Mikica
JessicaP
If you haven't heard back from the support team after 48 hours (2 days), feel free to let me know.
  • 7 Replies
  • 1384 Views
