I have 2 single camera subscription plan - paid. But I can only view the recording of 1 camera only. I login the my.arlo.com and can only view my profile and subscription plan. And I cannot control or change the cameras setting.
Are you using a mobile browser (phone or tablet)?
You need to use a PC to see the cameras in your browser.
Can you livestream the problem camera?
If you can, try making a manual recording while livestreaming and see if it shows up in your feed.
Thanks. I can view all cameras with PC browser now. But how can I update the 2 camera linking with my 2 paid single camera subscription plan. The web page setting has been changed and I cannot locate.
Try clicking on the profile option in the upper left. Then choose the Location (likely "home") and then Plans.
I can only locate the profile of my account setting.
What do you see when you click on subscription in the lower right?
I only see a single 1 camera plan but since I don't use those perhaps there's something I don't understand. If, in reality, you only have a one single camera plan that would likely be the issue.
