Just bought an Arlo Pro2 4 camera.
Can my wife and I be logged in at the same time?
When one of us is and the other one does -- it bumps the first one out.
That's normal behaviour for security. Use Settings, Grant Access to her (or your, depending on whose email the account is set up with) email address. Follow the emailed directions carefully. Both of you can then log in concurrently. The guest account doesn't have quite the same abilities, even with the access privileges enabled, but it's close.
