Arlo Pro2 Cameras VMB4000 Hub Battery Cameras Offline
  • 1 Reply
  • 250 Views
Lake45Ave
My Arlo Pro 2 wired and battery cameras went offline after (I think) a firmware update was pushed to the VMB4000 hub. All cameras showed offline, then the wired ones came back but not the battery ones.  After 2 days of troubleshooting I found that swapping the battery for the hard wired Arlo Pro2 camera the cameras came back online. So, if your battery powered Arlo Pro2 went offline recently connect it directly to power and it may reconnect.
ShayneS
@Lake45Ave
Thank you for the feedback, I'm glad they are back up and running.
  • 1 Reply
  • 251 Views
