Arlo Pro Base station offline
  • 2 Replies
  • 2538 Views
jerrydunn
Over the last week or so, I am constantly getting a "base station offline" message when I try to look at my cameras.  I get the message when connecting from my iPhone or on the web site on a PC.  The center light on the base station is amber when this error occurs.  The issue resolves itself after a few minutes and it is back to normal.  The issue will return again randomly but occurs multiple times an hour.  I have checked the Ethernet cable and the connection is good.  While the error is active, I can connect to the internet on other devices so the internet is fine.  I have also unplugged the power to the Arlo base station and it doesn't change anything.  Any help would be appreciated.
Try rebooting your router - that's worked in the past to fix similar issues.
jerrydunn
Thank you! That seems to have resolved my issue.
  • 2 Replies
  • 2539 Views
