Arlo Pro 2 without battery
  • 3038 Views
pbbgso
How do you use the Arlo Pro 2 without a battery? I plugged it in and removed the battery, but the app shows it as offline. I even rebooted the base station.
The camera should work fine without the battery if using the supplied ac adapter...
does for some reason need a re-sync ?
pbbgso
I wondered about that too. I am using the supplied adapter and cord that came with it. I pressed the sync button but it never came back up
Plug in the camera,
Make sure the Base button is pushed Quickly, don't hold...
press the camera sync button
  • 3039 Views
