All 4 of my cameras stop recording at 9;30pm and start back at 5:00am. I see that this issue has been mentioned but haven't saw a solution. I have tried everything to fix but nothing is working. Is there a fix to this issue?
Are you using the schedule? Have you rebooted the base? All details can help.
@jguerdat I rebooted and disconnected several times. No I’m not using the schedule. I need the cameras to go 24 hrs.
You can try removing and resyncing a camera to see if that helps. Otherwise, I would remove all devices from Settings, My Devices and start fresh. Be sure to note all settings, modes, rules, etc. to speed the rebuilding.
