One of my 5 Arlo Pro 2 cameras stopped working out of blue. I thought the battery died so I switched another battery. It still did not work. This was the camera kept inside the house and it was also plugged in. When I plugged the charger into the camera, the solid blue light appeared for 1 second before fast blink blue light for 2-3 seconds then it stopped responding. Holding the sync button would not get any response from it. The only time that LED light responds would be when it was first plugged in as described above. Please help.
Does the app say that the camera is offline or do you have some control like changing settings or live streaming?
Edit
I expect the camera would need to see a authentic request from the Base station before it would sync.
Sometimes rebooting the base station will fix it or using the web portal does, I have no insight to explain only evidence of reporting here on the forum.
Then try resync again.
Good luck with finding a faulty component or getting replacement parts.
You might have better luck with buying a second hand camera from eBay unless you want to buy a newer camera that requires subscription to have same functionality.
it happens the same to me. The only difference is that all the arlo pro 2 h5 stopped working at same time and all the arlo pro 2 h3 still work.
can you check if it is the same case?
@rleonanaya
The Pro 2 cameras appearing offline are connected to the same base station that also appears to be offline. Have you checked this base station to see if you can reboot it?
